Hi @fjmayer,
Try downgrading the URCap to version 1.0.1. You might also have to downgrade Polyscope to 3.3.4. We will address this issue with a new URCap release shortly.
David_Levasseur
Hi all, our latest URCap is not compatible with CB3 and the latest version of Polyscope. The two options here are to either upgrade your controller to CB3.1 (Read that post) or install this previous release of our URCap.
I'm only seeing .rar files for the software. Where do I find the .urcap file format?
Perfect! Thank you.
fjmayer
I just installed the actual sensor software (UCS-1.1.1) on a UR5. But the Active Drive Toolbar does not appear.
Polyscope shows the installed cap software, the sensor works great with test_sensor.urp.
I tried several times deleting/installing the cap with no change.
It's a CB3.0 robot updated with the newest Polyscope 3.4.1.59. The sensor is a FT300, the F85 Gripper on this robot works ok.
Maybe I should try the old legacy ADU-1.0.1 installer?
regards
Oliver
