We have a 2f-140 gripper that we can't connect to. I have tried using the ROS node, the UR5e teach pendant and the Robotiq User Interface. All fail and don't give a clear answer why.
ROS results in this error: AttributeError: 'ModbusIOException' object has no attribute 'getRegister'
With the robotiq user interface, error is the same as https://dof.robotiq.com/discussion/2245/2f-140-error-i-o-coupling-not-connected. The device information fields are empty
Usually the light is red, except when connected to the ur5e, then it is changing between blue and red.
Hope you can help me further!
