Hey everybody,I'm working right now on adaptive safety zones on a UR3. I figured out and programmed everything so that the robot changes its speed depending on position of human, directed speed of humam, directed speed of TCP. But unfortunately I couldn't find a way how to set the TCP speed while the robot executes a move command. I tried to work with the function interpolate_pose() to diskretize my path but with this function the robot slows down at every interpoint.Does everybody know how to set the speed during a move?Thanks,Dan
You can change the speed like you can do manually with the speed slider of the polyscope interface.You can check this other post for details:https://dof.robotiq.com/discussion/comment/2602#Comment_2602
Hey everybody,
Thanks,
Dan
