Are you running any URCaps? Some of them are using RTDE which is a field-bus and if their processes stop can cause a disconnect issue. Also, verify that the Profinet adapter is disabled as well.
No issues have occurred when running urcap 1.9.2 with polyscope 3.9. Robot has run for about 24 hrs
Guillaume_Charron
@ruddock111
Great news! Thanks for the update.
I have a UR10 running polyscope 3.9 and keep getting a protective stop message stating C207A0: Fieldbus input disconnected. The robot will run a few cycles and then trigger the error. i have researched the error code online and it states to ensure the ethernet/IP adapter is disabled which i have but the error keeps appearing.
