Hello @Sergio_Rendon, I opened a support ticket to help you resolve this issue. You should receive my email shortly.
Guillaume_Charron
@cianmartin,
Sergio's camera cable was defective, so he replaced it and it solved his issue. I will open a support ticket so we can investigate your problem.
I have the same issue. :( Suspect cable.
David_Levasseur
Hello
The LED on the cable of my robotiq wrist camera is blue, and the the color of the led on the body is red, in the camera tab on the installation menu it apears the message
Vision system down: usb camera is not detected, connect it and tap refresh
and in the status it shows
usb camera disconnected
Camera firmware obsolete
i have installed the latest update on the two components and the usb of the camera is well connected.
what could've the problem?
