dgrdgr Posts: 3 Apprentice
I'm using UR5 with 3.8 Polyscope with Polyscope set to Polish language (this setting is a culprit!).
I decided to update UCS 1.7.1 to newest version and I found a bug.
When I try to play program with Find Surface node I got following error.
Type error: rq_linear_search_urcap takes at most 5 arguments (7 given)
This error is related to Polyscope language settings. After changing to Int'eanglish this error disappeared.
Code with Polyscope set to Int eanglish:
   # begin: URCap Program Node
    #   Source: Robotiq_Force_Copilot, 1.9.0, Robotiq Inc.
    #   Type: Find Surface
    $ 7 "Find Surface"
    rq_ft_sensor_disconnected_check()
    surface_found = rq_linear_search_urcap("Z+",5,0.1000,0.1,1)
	$ 8 "'Add Stop conditions from the Command tab'"
    # 'Add Stop conditions from the Command tab'
    # end: URCap Program Node
Code with Polyscope set to Polish:
    $ 7 "Find Surface"
    surface_found = rq_linear_search_urcap("Z+",5,0,1000,0,1,1)
For some reason dot is changed to comma with Polyscope set to Polish.
Never had this problem with UCS 1.7.1.
