Hello @Enric, The error message you got is caused by the vision URCap and depends on the language of Polyscope. If you set it to English, you will get rid of the issue. This will be fixed shortly with the release of the new vision URCap which will be compatible for all languages.
Tyler_Berryman
Hello @Enric, the first limitation is designed to limit the part size that can be located using the Wrist Camera. The largest dimension that can be input in the parametric method's user interface is 500mm. I believe that this limitation is to avoid any errors or inaccuracies related to the camera being too far from the work plane or from distortion effects from the outer edge of the field of view.
Concerning the pallet wizard inside the Camera Locate node, I do not think that this is possible. However, I made a program that will allow to have multiple place positions based on the location of the object that is returned by the Wrist Camera:
Program
BeforeStart
parts≔0
Robot Program
MoveJ
Waypoint_1
Camera Locate
If parts≟0
MoveL
Waypoint_3
Waypoint_2
Gripper Open
Waypoint_3
If parts≟1
MoveL
Waypoint_5
Waypoint_4
Gripper Open
Waypoint_5
If parts≟2
MoveL
Waypoint_7
Waypoint_6
Gripper Open
Waypoint_7
If parts≟3
MoveL
Waypoint_9
Waypoint_8
Gripper Open
Waypoint_9
Halt
Set parts=parts+1The video of the this program is shown in this post : https://dof.robotiq.com/discussion/468/screw-insertion-using-robotiq-camera
David_Levasseur
Hi, Pros!
@Annick_Mottard
3.- Also I have detected an error with the Polyscopy 3.5.1.1 of UR and the Robotiq URcap V1.2.3
