After speaking with @jasontoh, I found out he was using a FT 150. Unfortunately, the sensor URCap 1.2.0 and followings are only compatible with the FT 300 and CB3.1. It is in UCS 1.2.0 that the dashboard, calibration and force injection features are introduced. Therefore, those new features will never work with a FT 150. Here is the latest URCap release for the FT 150 on a CB3.1. If, however your controller is a CB3, you will need this release instead in order to be able to use the Active drive toolbar.
David_Levasseur
Hello @cserteGT3, you should start by updating Polyscope to the latest release. If you still have issues, please contact support@robotiq.com
David_Levasseur
Hello @lawrence, the latest version of the FT 150 URCap depends on the version of your controller. For a CB 3.0, the version is UCS 1.0.3. and for a CB 3.1, the version is UCS 1.1.1. The instruction manual can be found right here. For any other question you might have on previous versions of Robotiq products, please visit the Archives section of our website.
Hi there,David_Levasseur said:Hello @lawrence, the latest version of the FT 150 URCap depends on the version of your controller. For a CB 3.0, the version is UCS 1.0.3. and for a CB 3.1, the version is UCS 1.1.1. The instruction manual can be found right here. For any other question you might have on previous versions of Robotiq products, please visit the Archives section of our website.
I still have the FT150 and would like to use it on the UR CB3.1, is the latest URCap is this still available? (I will probably have to downgrade my UR)
Hope someone cane assist.
i have installed the FT Force Sensor on my UR5 robot. But the Dashboard is missing. what i have is as shown below
