Hello, I’m looking for a gripper that is able to handle a 20 kg board. Within the tool we also need to fasten screws through the board at the same time as it is gripped. A mechanical linear joint is therefore needed perpendicular against the board to feed the screw as it is penetrated through the board. Any suggestions on that. Thanks in advance, Shehab
Thanks in advance,
Shehab
