@VT_340 you can use this script function, set_tcp(pose), to change the tcp by passing in a pose representing the offset in x, y z and the rotation of the tcp around x, y and z
Here is an example of the script code from one of our production programs that has 3 TCP's, this is the script that was generated from the .urp polyscope file but it shows you how its used.
. set_tcp(p[-0.11324,0.0,0.11216,0.0,-0.757,0.0])
set_payload(2.0, [0.0, 0.0, 0.1])
set_gravity([0.0, 0.0, 9.82])The set_payload has 2 arguments, the mass in kg, in this case 2, and the CoG in meters from the tool flange
The set_gravity is telling the system the magnitude of gravity in each of the axes, in this case the robot is mounted normally (base parallel with the ground) so all of the gravity is acting in a single axis, Z.
Hi!
I am wondering about that it is not easily possible to change the TCP-Offset via URScript?!
Is there any trick how to manage that? Basically I want to have the same trajectory with different tool-geometries. In the Dashboard you can set this easily in the configuration tab, so I thought this is possible via URScript as well? If not my whole project will fail, as I always thought this is easily manageable.
Thanks in advance.
A.B
