Hi Pros, Would you be interested in streaming your data from your Force Torque Sensor directly on a CSV file as shown in the video below?If so, it’s possible with this trick! Learn how by downloading this program template here.https://www.youtube.com/watch?v=68NImIE__Hc&feature=youtu.be
@David_Gariepy Good job and very helpful! Is it possible to use that app with a sensor not from Robotiq?
I don't think so, unless your sensor is using the same port and and data are being sent under the same format. But the code is included in the template so you can modify it for your own use.
