Hi @wukong
Could you be more specific about the ROS distro you are using, what driver (link to a repo), if you are compiling from source or installing from binaries, what gripper (2 or 3 fingers), steps you have done so far, so the help would be more accurate?
Best
Hi@carlosjoserg ,
Thanks for your reply!
My ROS distro is indigo, and the repo link is https://github.com/StanleyInnovation/robotiq_85_gripper, and the gripper is robotiq 2 finger(85). I connect the gripper to Linx via the USB of the gripper and camera supplied by robotiq company. And I run the driver node, the wrong is happened as below.
And actually after I load the USB, the Linux can't find any USB devices.
BEST
When I connect the gripper to Linux(14.04) via USB(serial to USb), I can't find any ttyUSB, but the LInux have already installed the FTDI driver. I need your help.
