Hi Alib,
You can do this by using the script command: "ignore_snapshot_position = True" before each additional camera locate. Then just copy and paste your camera locate and movel.
But you need to keep the same distance from the part you want to detect.
David_Gariepy
Click advance tab --> Script code and enter the following script code :
ignore_snapshot_position= True
Tyler_Berryman
Hi, I am wondering if it possible to find a part (same one) from multiple positions, i.e. so you can look for a part over a larger surface area in one program, but only have to teach part and pick up once? At the moment i am teaching part and movel for each snapshop position, but it seems like UR should know the part after being taught once?
