iremnurtokac
mbartczak said:
I am having the same error of C192A20.  Is replacing the SCB the only way to clear this error?  Other than adding an external power supply?
I am having the same problem. Did you find any other solution?
pogenest
Hello mbartczak and iremnurtokac,
This error is caused from the power terminal block.
There are, at least, 4 causes for this error.
The power terminal block is not being plugged in
The power terminal block is loose jumper cable (the screw are unscrewed)
The power terminal block is missing jumper cable
At least on 24V fuses is blown.
