I'm not an expert in Polyscope scripting, but if I were to program those safety constraints, I'd make the reduced space (R) to overwrite the normal space (N) in case of ambiguities, precisely for safety reasons, which explains the issue you are having.
Check whether other available constraints can help you model your normal space (N).
MarcAntoine_Lacasse
Fionn_Merz
Hi all,
when we create two security planes of this kind, the robot will work normally (N) in the middle of the planes and it will go in reduce mode (R) outside. The arrows show where the robot will work normally.
But if we create this kind of planes
the robot will work in reduce mode in each areas, why?
We can't understand why the robot works in reduce mode despite it is in the normal areas.
