@abeachy_HG24 have you tried swaping coupling? We should try to isolate the source of this, it could be a defect / bad connection within the coupling or within the Gripper.
If it's the coupling we will send you a replacement right away. If it's the Gripper we will do a RMA for repair at Robotiq.
One of our grippers is not responding. the LED on the gripper is a solid red light. I can not activate the gripper from the toolbar. I also tried creating a program with script to reset and then activate the gripper but that did not work either. I checked the cable and the wires and those seem to be okay. I also reinstalled the URcaps 1.0.2. This UR is running 3.3.4.310.
