You can connect any camera to the UR5. I have been using Teledyne Dalsa cameras to locate and verify with the URs for a while now. You can either have them mounted externally or on the end of arm. Communication can be over MODBUS or depending on the information you want to send, Digital I/O.
Heres a link to one of our videos using a wrist mounted Dalsa BOAII camera for part location. With proper lensing, lighting and resolution, you should be able to detect the hole. http://www.youtube.com/watch?v=w7-KGaYGuMA
Kevin_Matthews
Annick_Mottard
I want to detect a hole where I want to insert a screw. The Problem is the hole is to small -> Object is smaller then one grid cell. I tried getting closer to the hole but then the working space is to small. Does somebody have any hints how to fix this problem? Is it possible to connect any camera with the UR5 or has it to be the wrist camera?
Best Regrads!
