Hi pros,The path recording function allows to record a path, so I assume a set of point position recorded. I was wondering if it also allows, at the same time, to record the velocity at each point position?
@mikebeauchemin I believe so since you have the option to run the path at the taught speed or constant speed.
Hi pros,
