Hi @Enric,
It doesn't seems too bad for now, do you have the opportunity to check the # of cycles on the Gripper ? If the noise does not affect your position feedback, object detection or grip force I wouldn't be concerned by this.
With the wear of the transmission you can expect a slight increase in backlash and noise from the Gripper. When we do maintenance that should all comeback to normal.
Enric
Hi, @Etienne_Samson
After time working, the gripper opens and makes a soft noise (double click). The noise does when the clamp opens with an object. It can be mechanical problem?
https://youtu.be/O18pluK-0zk
Best!
