There is no actual limit to the length or duration of the path you want to record. The only limit would be the available memory to store your program in. Also, if you record a long path, the inconvenience is the time it takes for your program to start running. The longer your path is, the longer it takes before your program actually runs when you click the start button.
Like you mentioned, @mikebeauchemin, it is easier to work with smaller paths. It is much simpler to correct an error while recording a smaller path.
Annick_Mottard
mikebeauchemin
Hi everyone,
I had today a question from a customer on the maximum length / duration allowed for a path recording program using our URCap function. My first answer was to say that the only limitation was the memory left on the controller to run / record such program.
I also mentioned that from a programming standpoint, it's definitely more convenient to work with a set of smaller path recording segment programs than a single long one when comes the time to modify it, since as of now, it's not possible to edit the path recording program.
@Nicolas_Lauzier @Annick_Mottard Do you see other limitations?
