@Sebastien you can use the camera on a UR that has a replaced joint. However, there are some guidelines that need to be followed if you want to keep the vision system’s accuracy that you had before joint replacement.
Following the UR joint replacement procedure, you will see at the end of it that you need to calibrate the robot when you change a joint. There are a few ways to do this and the best way being the dual robot calibration procedure. All this information can be found in the service manual that can be downloaded on the UR support website. Once the robot has been calibrated, you should define new Snapshot positions to use within your Camera Locate nodes. Remember to save your installation file after defining a new Snapshot position. And you should be up and running just like you were before joint replacement!
@Stefan_Stubgaard what are your inputs on this?
Annick_Mottard
Stefan_Stubgaard
Can I use the vision system on a robot with a replaced joint? Do I need to recalibrate the robot after the joint has been replaced?
