Hi June,
The tutorials for that ROS package are a bit outdated, and I guess you are following them.
Check this issue on the ros-industrial github repo: https://github.com/ros-industrial/robotiq/issues/45
There, I describe how to do use that driver on the USB interface to someone having the same issue.
If you need a modern ros-control-based driver using the USB interface as well, you can check our fork at: https://github.com/beta-robots/robotiq
(all packages called robotiq_2f_*)
Where there is also the URDF for the new 2-finger model (not in ros-i as far as I could see).
Let me know if you have issues.
Best
Welcome @Etienne_Samson !
Oh, I had't seen @Laurie 's post: http://dof.robotiq.com/discussion/199/ros-package-tutorial-for-the-2-finger I misread and thought @June was referring to the ROS wiki tutorials.
Anyway, I see that the config file for the USB driver is also missing, which was necessary for me, at least for the new 85mm model. Note that, the bash script I mention in the github issue to generate this config file comes from the USB driver used in the URCaps package by Robotiq itself, which in fact runs in a Debian machine.
@Laurie feel free to include to the tutorial any additional step I commented on the github issue.
@June forgot to ask to be sure as well: could you describe more your system, Linux and ROS distro, etc.? are you using the USB adapter from Robotiq? Source or binary packages? Now that I re-read it seems weird that the system chooses ttyACM* over ttyUSB* for you
Best
Catherine_Bernier
Annick_Mottard
Tutorial using "robotiq_c_model_control" was uploaded here "http://dof.robotiq.com/discussion/199/ros-package-tutorial-for-the-2-finger".
I have a trouble on connecting the 2-finger gripper while following this tutorial.
After the command below is executed, the LED turns on the blue. But the LED becomes red again soon.
$ rosrun robotiq_c_model_control CModelRtuNode.py /dev/ttyUSB0
In my case, the command below is executed.
$ rosrun robotiq_c_model_control CModelRtuNode.py /dev/ttyACM0
How can I solve this problem?
I have a error message below.
/home/user/catkin_ws/src/robotiq/robotiq_c_model_control/nodes/CModelRtuNode.py:65: SyntaxWarning: The publisher should be created with an explicit keyword argument 'queue_size'. Please see http://wiki.ros.org/rospy/Overview/Publishers%20and%20Subscribers for more information.
pub = rospy.Publisher('CModelRobotInput', inputMsg.CModel_robot_input)
Traceback (most recent call last):
File "/home/user/catkin_ws/src/robotiq/robotiq_c_model_control/nodes/CModelRtuNode.py", line 89, in <module>
mainLoop(sys.argv[1])
File "/home/user/catkin_ws/src/robotiq/robotiq_c_model_control/nodes/CModelRtuNode.py", line 82, in mainLoop
gripper.sendCommand()
File "/home/user/catkin_ws/src/robotiq/robotiq_c_model_control/src/robotiq_c_model_control/baseCModel.py", line 101, in sendCommand
self.client.sendCommand(self.message)
File "/home/user/catkin_ws/src/robotiq/robotiq_modbus_rtu/src/robotiq_modbus_rtu/comModbusRtu.py", line 80, in sendCommand
self.client.write_registers(0x03E8, message, unit=0x0009)
File "build/bdist.linux-i686/egg/pymodbus/client/common.py", line 98, in write_registers
File "build/bdist.linux-i686/egg/pymodbus/client/sync.py", line 83, in execute
File "build/bdist.linux-i686/egg/pymodbus/transaction.py", line 64, in execute
File "build/bdist.linux-i686/egg/pymodbus/client/sync.py", line 354, in _recv
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 460, in read
raise SerialException('device reports readiness to read but returned no data (device disconnected?)')
serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected?)
