Hi @matthewd92,
Our Active Drive guiding mode works inside of the UR force mode in order to have stable contacts (which is helpful when using a part to guide the tool). This mode is more restrictive than the normal motion of the robot. The exact metric that they use to trigger this popup is however not documented.
Ideally, we would restrict the motion of the Active Drive mode to make sure we never see this error. I will request this feature to UR such that we may include it in a future version of the sensor URCap.
Meanwhile, the only thing I would suggest is to stay as far away as possible of the singularities. I understand that in the above picture you are not in a singularity if your TCP is defined at the tip of the fingers. However, my guess is that the force mode may be using the tool flange of the robot in its computation, in which case the robot pose is close to the axis of the first joint (I think the controller forbids a cylinder zone around the axis of the first joint).
Catherine_Bernier
@Beachy Here is what Robotiq + UR is saying about this issue.
Nicolas_Lauzier
Stefan_Stubgaard
We were trying to do some work today with the FT150, both teaching a path as well as just moving it around to various waypoints. We kept getting an error though about the robot cannot operate in force mode when in a singularity. As far as we could tell the robot was not in any type of singularity. Is there a range of motion that the force mode does not operate within? Here is an example of one of the positions that we were in when we received the error.
