Hi @Kaleb_Rodes ,
I contacted you directly to get further information on your issue. I will do a follow up on this post afterwards to give more details on this type of error message.
Annick_Mottard
@Micusan
I just opened up a support ticket for you. We will address the issue and get back on DoF when we know more.
Annick_Mottard
Hi all!
It seems the issue @Micusan was experiencing has been resolved a couple of weeks ago, with the appropriate connections.
David_Levasseur
Hello @sabine_giron,
The vision server does not seem to be installed. When you download the vision URCap, there is also a folder called vision_system that you need to extract. Copy this folder at the root of the USB stick connected to the USB hub and then you will be able to install the vision server. The full procedure is accessible in this section of the instruction manual.
Received the following error this morning after installing the wrist camera on one of our CB3.1 UR5 demo units:
Any help would be greatly appreciated!
Note: the same dongle and usb stick have been used on a different robot previously.
