@Tyler_Berryman when you perform the calibration using the calib_tool.urp program, the calibration is actually saved within the sensor. Therefore, when you reset the robot, you do not need to do the calibration over again.
You need to perform the calibration once each time you mount the sensor on a robot arm. The screws used to fix it may induce stress that can affect the signal. The calibration will compensate for those effects. You can also perform it once each time you change the end effector mounted on the sensor, since the calibration also compensate for an added mass and a different center of mass.
Annick_Mottard
Hi guys,
I was wondering if I have to run the calib_tool.urp file to calibrate the sensor after I reset the robot? Or is the calibration saved in the installation file?
