When you buy the 3F you can choose the communication protocol.
If you have the Modbus TCP version for example, you can control the gripper via ethernet thought the communication cable provided with the gripper using Modbus TCP protocol.
It is also possible to control the gripper using the RS485 wires of the power cable and communicate using modbus RTU.
For trouble shooting it is possible to use the USB port of the gripper to connect the gripper on the USB port of your PC and control is with robotiq user interface software.
All 3F have modbus RTU communication available but most of the time modbus TCP or other ethernet protocol are used to control the gripper.
We have a ROS package to controller the 3F with Modbus TCP:
http://wiki.ros.org/robotiq_3f_gripper_control?distro=kinetic
Here is tutorial to make it works:
http://wiki.ros.org/robotiq/Tutorials
If this ROS package does not fit your need you can eventually write your own package. The 3F can be controlled by reading and writing its registers. You can find more information about it in its manual:
https://assets.robotiq.com/website-assets/support_documents/document/3-Finger_PDF_20210617.pdf
Hello Robotiq community,
We got a ROBOTIQ 3F gripper, and I am trying to figure out the communication connection. If possible, I want to use only one cable for power and communication. After reading the manual, this does not seem to be possible, but I wanted to confirm with you.
The manual says that the RS485 serials pins (inside the power connecter) are UNUSED. I highlighted it.
Just for confirmation, does this mean those pins can not be used for communication, and another dedicated cable is needed?
If the answer is yes, will the best option be the Ethernet, or is USB equivalent to it?
I am looking forward to your reply. Thanks!
Best regards,
Raessa
