@PaulKeeling I assume you mean mounted so that the locating hole is not lined up with the one on the flange?
My guess is that the offsets (relative moves) under the camera locate node will all be wrong because the axes being commanded do not line up physically with the way the camera is mounted. Same as the force torque sensor. If it is mounted incorrectly it will report forces along the wrong axes.
Grady_Turner
Alexandre_Pare
JeanPhilippe_Jobin
LouisAlexis_Demers
I was wondering how does the camera handle different mounting positions?
Cheers,
Paul
