hi @matthewd92 ,In Cognex side, 1) I am using a nattive command communication via TCP/IP. 2) I checked via the telnet portal on PC it's working. 3) I send a command via typing the portal.like that, I plan to send and receive a string to cognex via socket programming in UR side 1) I opened a port 2) receive a string it's coming 3) I send a string it's not received on the camera side what is the problem I don't know so I will share a picture of my program
@Malai_R_Prog I have not worked with a Cognex camera system in over 3 years. I would recommend reaching out to Cognex for support.Thanks,Matt
hi @matthewd92 In Cognex it's working sir we use telnet portal for sending instructions to insight software.in the UR robot side I received a value but I send the string but it not received in camera side Socket_ send_string("admin")var_1:= Socket_ send_string("admin")variables :var_1:= True
hi @matthewd92 ,
In Cognex side,
in UR side
1) I opened a port
