Hi,I'm currently experimenting with cameras to identify objects and drive robotic arms to grasp them.But I find the accuracy is not good enough. I recalibrated the transfer between the camera and UR10. But it does not make a difference.So I'm wondering if the TCPPose I get from the getActualTCPPose() function is accurate or not?Do I need to calibrate the TCP before I use the RTDE Control interface? (It's not a new robot, someone has used it before me.)B.R.
Hi, did you manage to figure this out ? In order to get the actual TCP pose you will need to measure in the TCP.
B.R.
