I am having this same issue. I have rebooted the robot and took the end effector off to clean the pin connectors. I have even deleted and reloaded the force copilot URcaps. It still is not working and I cannot even turn the robot on to move it.
@arnoldgauge Glad to hear that. Do you know what may cause this kind of issue? Mines was literally unmoved for a few days and this issue occurred when I tried to start it...
arnoldgauge
I've had a few of my UR5Es fail with a C45041 Error about a missing Force-Torque sensor in the last week. When the first robot failed on Tuesday, we swapped with another unused robot and it temporarily fixed the problem. The plant just called and said the problem reoccurred on the first robot, and the same problem happened on another robot in the same cell.
The original problem happened on Polyscope 5.9. We upgraded them to 5.11 with no changes. Newer robots, still under warranty. Here is a video of the machine: https://www.youtube.com/watch?v=0PhGCsveb5Y
Has anyone seen a similar problem? The Message in the log and HMI is ToolA : C450A4: Force-Torque sensor: Force-Torque Sensor is expected, but it cannot be detected.
