Please go to support.robotiq.com ➜ Browse by product ➜ Force Copilot ➜ Universal Robots ➜ Software ➜ Force Copilot Software ➜ Download Zip.
The improvements and bugfixes implemented are shown below:
[BUGFIX] Fixed a URCap issue that could generate an error when adding a path using the External tooling option of the Path node.
[BUGFIX] Corrected a problem that caused the carriage to be in a negative position and triggered an invalid JSON error with the Palletizing application.
[IMPROVEMENTS] Improved the general robustness of the Palletizing program nodes.
[IMPROVEMENTS] It is now possible to hide/show specific nodes in the Program tab.
[IMPROVEMENTS] Palletizing Solution: Moved the linear axis’s initialization command in the ActiveDrive Toolbar.
Please note this URCap was tested on:
PolyScope 3.15.1
PolyScope 5.10.1
Please contact the Robotiq Support Team at support@robotiq.com should you have questions or comments.
Hello Crew,
On May 26, 2021, Robotiq put online version 1.20.0 of the Copilot URCap (UCS-1.20.0).
PolyScope 3.15.1
PolyScope 5.10.1
Cheers.
