Hello, I want to use calib_tool.urp of DFU to calibrate FT300 on my ur3 CB3, but it appears that "The installation file cannot be found, you cannot load the program before the program exists, or create the program manually." Another question is that if I want to use Copilot URCap, Should I obtain the license first?How should I solve it?Thank you.
I am not sure about what is calib_tool.urpIf you have a FT300, you can install Copilot URCAP. You don't need a license.I open a support ticket to follow your installation.
I decompress UCS-1.19.1 in my blank USB, but it appeared that license needed when I open it after installation completed. should I use USB license dongle and how can I get it?
Thank you.
