Arduino have 13 IO pins with voltage of 0 to 5V.
UR controller also have IO but the voltage is 0 to 24V.
You could connect an IO output of UR controller to the arduino via a relay.
- UR output goes high (24V)
- Under the 24V the relay switch on
- With relay on the input pin of the arduino is supplied with 5V
I want the cobot to send a signal to my arduino so that the arduino knows when to use the steppermotor. Is it as easy to just have a single wire between the cobot and the arduino??
Hope someone could help
Max Huizing
