Hi @MartySeal
It can work and we have seen it in the past.
Few things to keep in mind:
- The Robotiq grippers works in Modbus RTU. In most cases, the LR Mate will work in Ethernet IP. You will then need a Universal Controller to connect in between to "translate" the communication between the robot and the gripper.
- The the gripper functions are available. Since we don't have a plug and play software to go with this robot, you will have to map the registers of the gripper.
Hope this helps.
Thanks!
MarcAntoine_Gauthier
I want to install a Hand E gripper on a Fanuc LR Mate robot. I have never used Robotiq grippers. Good idea or bad idea for machine tending?
