Hi pros, I am having a problem using the copilot (sanding kit) on a robot that needs the ethernet IP adapter to communicate with a PLC. Is there any way to use an older version of the urcap or any other by pass that would let me use those 2 things at the same time? As I understand the copilot use some registers that are also used by the ethernet/IP adapter. How did you guys deal with this complication?thanks
Hi I have the same issue with the Copilot URCap (Palletizing solution)The ethernet/IP is somehow blocked when the Copilot URCap is installed.I started another thread for this.Thanks
Hi pros,
thanks
