UNI-CTR-001-ENIP is only compatible with our grippers (2F, hand-e, epick, airpick). It won t work with the FT300.
For the FT300 you have to purchase an equivalent devise from a supplier and do the configuration by your own.
We often give https://www.anybus.com/ as a reference to purchase such devise.
What material do I need to connect the FT300 to a PLC via ethernet IP?
The refresh rate of my real-time controller is between 2 and 4 milliseconds. I would like the force and torque signal to have as little latency (lag) as possible.
Do I need de UNI-CTR-001-ENIP controler?
