If you want to make your own force control algorithm using ROS, I would recommend that you directly connect the FT300 on your PC and work with the raw data of the sensor.
Force mode is a preprogrammed force control algorithm. It will not fit if you want to make your own force control algorithm.
For your information we have a ROS package for the FT300:
http://wiki.ros.org/robotiq_ft_sensor?distro=kinetic
Sorry, I didn't understand you.
https://github.com/UniversalRobots/Universal_Robots_ROS_Driver/issues/269
Do you mean that ROS can not use ur3e integrated force sensor?
So should I use ft300 with ROS?
Do you mean that E series integrated force sensors can not get the correct force data in the position mode?bcastets said:If you want to make your own force control algorithm using ROS, I would recommend that you directly connect the FT300 on your PC and work with the raw data of the sensor.
Do you mean that E series's integrated force sensors can not get the correct force data in the position mode?bcastets said:If you want to make your own force control algorithm using ROS, I would recommend that you directly connect the FT300 on your PC and work with the raw data of the sensor.
So I have to use external FT sensor to realize force control with ROS?
