You can connect the universal controller to your PC via an ethernet port and control it with RUI if you have a Modbus TCP universal controller.
You also need to set a fixed IP on your PC.
The IP of the universal controller is: 192.168.1.11
You can set this fixed IP on your PC:192.168.1.10
I think you have an EtherCAT controller so you won't be able to connect on RUI via ethernet. Only a USB-USB connection is possible with RUI.
I would recommend that you ask for the help of an integrator for your project.
Unfortunately, we cannot do this integration for you.
I hope this will solve your issue. Do not hesitate to contact us if you have any other questions regarding this issue.
Kind regards,
MarcAndre_Baron
Hi
I'm trying to communicate with the universal (K-1874) controller though Ethernet/IP connection, however all my attempt were unsuccessful.
I figured out that there is no connection whatsoever though the Ethernet port of my Desktop though control panel --> networks and Internet --> network and sharing center. Which doesn't show the any Ethernet connection.
However I can connect and used the gripper using the USB to USB port.
Regards
