To be able to record a path applying a constant force perpendicular to the speed. This could help a lot in deburring, gluing and similar applications.
It would be nice to set this force either using defined values or % of a pressure test done by hand. So the operator could teach the same force he is applying when he does the task manually.
Samuel_Bouchard
@PaulKeeling what are your thoughts on this?
Catherine_Bernier
Grady_Turner
Adam_Boike
Alexandre_Pare
We are currently defining what should be the next improvements / feature addition to the FT sensor URCap. Are there current functionalities that should be improved? Why? If you had only one feature to add, what would it be and why?
