Hello, I partially solved this. Connection seems to be working with AGC-CPL-FTSENSOR, but with AGC-CPL-062-002 it won't work. We'll do more troubleshooting with it later on. Would it be possible to get **pinout charts for 2F's base connector**? I could beep that cable/coupling with multimeter if it's ok or not. Probable cause of those connection issues is due to slight oxidation in connection surfaces, as those demo kits have been stored in garage which is just some degrees (3-8) above zero degrees celsius at winter.
Enric
Hi, @Etienne_SamsonEtienne_Samson said:Hi there,
The attached PDF as the pin-out on the pigtail connector with spring pins, it match to the Gripper.It is probable that you have some oxydation, I had to clean my demo kit spring pins with alcool pads quite a few time.
We have a client with a gripper that the LED is not light up.
The "pigtail" has been changed and still the same. chequing pins and we have voltage between pins (GND) & (VON), but between (GND) & (24V) does not have tension.
Is this normal?
Best
Best
Robotiq_Customer
Hello, We're unable to communicate with our gripper. We've tried with our table stand coupling(AGC-CPL-062-002) and with FTS-coupling(AGC-CPL-FTSENSOR), with later one Gripper will power on, and shows shows red light constantly. With table stand led stays off, so there might be some other issues with it. USB-RS485 converter is randomly blinking red led slowly, but mostly staying off. I'll try to do a bit more troubleshooting to see if I can connect to gripper somehow and/or rule out faulty components. Hoping to hear from you soon, as we're setting up our next fair demo with these products and third party software...
