Will it be possible to export data from the vision system such as the position and orientation of a part that it has located? A bit of background on my request:
I'm working on a work cell for a UR robot but I need to be able to relocate the arm from week to week to different work cells. We're aiming for pretty good precision so I'm working on making an automated calibration protocol for the arm that I could run each time I relocate the arm. Currently that involves essentially transforming the arm into a CMM machine to locate a part of the cell. Ideally though, I'd like to be able to use the vision system to take a picture of a target in my work cell and have the vision system output a position and orientation of this target with respect to the base frame of the robot. I'd then use that information as a starting point to generate the displacement vectors and rotation matrices for all subsequent operations to be performed in the work cell. Would there be any kind of URscript command that would output this kind of information?
Thanks!
Sean Fielding
MDA
Nicolas_Lauzier
- Can the vision system do quality inspection?
No. The vision system is used for part detection, it cannot measure dimensions.
