When you have reflections with the camera you can:
- Take the picture with the camera lens inclined compare to the workplan. The maximum reflection is when you have the camera lens parallel to working plan with the LED on. Having an angle will avoid LED light reflection. I would recommend to use holes you have in the part as feature to make you object model. Light does not enter holes so they should appear as blank while the surrounding should be brighter.
- Switch off LED and set surrounding lighting which avoid light reflection. Maybe side lighting could help.
                 Galyion
                    Galyion
I’m trying to get our ur5e with wrist camera and hand-e to reliably find parts coming out of the conveyor on our Swiss lathe.
