You will probably need to send the pendant to UR for repair if you swapped pendants and the other one does not exhibit the same issue
Thank you again.
You’re welcome
Thank you again.
You’re welcome
I'm working with a UR3, when I try to initialize the robot it shows me "Error C192A2: Robot emergency stop disagreement". I replace the teach pendant with other robot and it works, so the problem is the teach pendant. Checked the emergency button and the cable like the manual says, also short-circuited the contact directly on the PCB inside the teach.
Would you recommend another test? I can't think another idea to test.
