https://youtu.be/pCIXP-b6ULMI didn't changed any hardware settings, and it worked a month ago.There doesn't seem any problem in hardware setting. But i could find the green led blinking irregularly as you can see in the video.As you can see in the video, i also fixxed the IP but i can't figure out what's the problem.I'm not familiar with computer settings, so the detailed explanation with descriptions would be very nice.I re-installed Robotiq user interface to the latest version, and also wiggled the COM port, but it didn't work.I guess there exist some software problem with communication, as the instruction manual says that if green LED is blinking, Network is detected, but no communication is established.
The default gripper IP is 192.168.1.11. However your PC have same IP. You need to set a different IP for you PC (ex:192.168.1.10).Try changing the IP of your PC.If you are still facing problem, please contact support@robotiq.com.
