Hello, I am trying to wire a In-Sight 9912 cognex camera to UR10e Controller, but i couldn't find wiring manual. Can someone help me with that. Thank you. Best Regards
I did email them. I thought that I could find a guide online, but it seems to be not that easy to find. I will wait for their response. Thank you.
I got an answer from them, they did provide me with a user Manual, but i still have no idea how to wire the camera to the controller. I will provide screenshot of the Breakout cable and the controller from UR10e in case if someone can help.
I not familiar with this camera but if it is plug&play with UR, it should come with an URCAP.You may found additional information in the URCAP.There must be a predefined way to connect the camera on the controller.If it is not plug&play, you will have to go deeper in the document and understand how to communicate with the camera.Then you will have to write a program to handle communication using the I/O of your preference.Once again I would recommend to get further information from Cognex.
