Hey Matt, yes this can be doable and also Robotiq now has fingertips extenders that can be used on Hand-E. They will offer you from 40mm to 100mm of opening and any 2F fingertips can work on those.
This is a base that you can work with to extend to the size you want and easier to customize. However, keep in mind that the forces applied on the gripper needs to remain inside the limit of the gripper. (More info in the manual)
Here is an image:
Ask your distributor to get them.
Thanks!
NVM asking my distributer. Thanks again!MattJones said:Thank you! How/where do I purchase these?
Here below is the link to download our fingertip catalogue:
https://assets.robotiq.com/website-assets/support_documents/document/Offering_20FingertipsF_FE2020_F_20200313.pdf
The following items are necessary to replicate the same setup:
- HND-TIP-EXT-KIT Finger extender kit
- AGC-TIP-MLD-KIT-85 Flat rubber overmolded fingertip kit
We may have some in stock if you need them.
The reference is: AGC-TIP-204-085 Flat Silicone Fingertip for 2F-85-V4
Catherine_Bernier
Hello DoF community!
I'm new, got my UR5e and Hand-E gripper last week. Currently the rubber fingers are 2 inches wide (open) I need the grippers to go as wide as 4.5 - 5 inches. My idea is to ad 1.5 inch extensions to each finger. It wouldn't be able to close completely but thats ok for my purposes. Any thoughts and ideas would be grateful. I was thinking I could get these extensions 3D printed maybe.
