I made a quick check of the datasheet of the liniar actuator.
https://s3.amazonaws.com/actuonix/Actuonix+L16+Datasheet.pdf
It looks like the best will be to use this actuator in combination with a control board:
https://www.actuonix.com/LAC-Board-p/lac.htm
Datasheet:
https://s3.amazonaws.com/actuonix/Actuonix+LAC+Datasheet.pdf
You can also contact the support of Actuonix.
It is probably better to use this controller than making your own control solution.
Looking to set up a linear actuator like the one linked below:
https://www.actuonix.com/L16-Linear-Actuators-p/l16-p.htm
What would be the best way of connecting it up? it comes with analog positional feedback. was looking into connecting it into a h bridge
