David_Gouffe
I do not have a WAGO remote IO Modbus fieldbus coupler.
But I think I can guess what happened to you:
The I/O are probably at the last value they had the last time they changed. This viewed by the WAGO Module.
The idea is that at boot you probably need to update all your remote IO to really control the actual state of each of them.
Not ideal but can occur if the master is not refreshing the output at boot. Might be normal behaviour for Modbus.
Hope this helps a little.
Regards,
David Gouffé
Integration Coach
Coach en intégration
1-418-655-9221 (Cell)
