Hi @timuvlad
If I understand you want to apply a constant force while drilling until you reach a specific position right?
Attached is a program example, here what it looks like
Program
Robot Program
MoveJ
Waypoint_1
Force Control
Wait current_pos[2]<0.1
Popup
Thread_1
current_pos≔get_actual_tcp_pose()
sync()
In this example, the force control node is used to apply pressure until the wait condition is met. In this case, I'm waiting until the z position reaches 100 from the robot base.
The thread is used to get the actual position of the robot
Hope that help
Hope that help
David_Gariepy
I am currently trying to use a force torque sensor to perform a drilling application and I am facing the following problem. I have used the force control option to maintain a constant force along the drilling path and then I used the F/T move and F/T waypoint in order to move the robot through the material ( I have calculated the positions before this node by getting the actual tcp position and setting another variable with coordinates changed on the z axis for downard movement followed by the 'transpose' func. to move the robot from starting pos to end pos of the drilling path). F/T waypoints are implemente based on these variables that contain the position before getting into the material and the end position using the 'transpose' func. I have set the threshold value for the force on z axis in the F/T Move but the problem is that whole program stops when that force is reached along selected axis. I can't seem to make the robot follow the next lines of code after the F/T Move force threshold is reached. Does anyone have an idea that could make this work?
