Have you set up the IP address, by default it’s turned off. Depending on CB3 or e-series the path to the network setting is different. On CB3 on the main screen go to Setup robot and then network settings. On the e-series clock on the “hamburger” on the top right and then go to settings. Network is under system settings.
The robot can use either DHCP or static IP addresses.
How can I find my Robots IP Address? Does the UR even have its own IP Address? I went to About.. and it said 000.000.00.00.
